I was told recently by one of the guys at the local doo shop that I should consider using more than 91 octane in my 03 Summit 800. He suggested that I get model airplane fuel and mix 2 oz of that with every gallon of fuel I ran in the sled. He said this misture would raise the fuel to about 100 octane. I have never had any problems with running normal 91 octane, but I figured I might as well give it a shot. Instead of going to full out 100 octane, I bought 93 octance from the gas station and added an octane boosting compound. I crunched the numbers and I am pretty sure that the last tank of gas I ran through the engine was 96 octane. Now call me crazy, but I started the sled and as soon as it burned through the remaining 91 octane in the fuel line and starting sucking in the 96 octane, the idle rpms went down considerably(almost 400 rpms). I guess this makes sense since the higher the octane, the slower the fuel burns??? (I am not sure about that, I never paid attention in my petrol engineering class.) So i got out the next day in some deep snow and rallied around for about half an hour. The sled ran phenominally well!!! I was stoked, but then I got to wondering about the jetting and all the other stuff that the higher octance could potentially mess with. I am rather ignorant about snomobile engines, so I was wondering if you sled goo-roos could help me out with these questions.
1. Are there long/short term harmful consequences to running above 91 octane without adjusting anything?
2. Am I on crack or would the higher octane really make the engine idle lower and run better?
3. Should I stick with 91 octance or am I safe to play around with the fuel mixture
4. Is the model airplane fuel the best way to raise octane or should I continue to use regular octane booster.
Any help you all could give me in this would be greatly appreciated!!
Thanks
Thanks
