J
HELP!! I need a PCV map that actually works for my 2014 M8000.
I've tried the map from the Bikeman site, ARCTIC CAT 2012 PROCROSS/PROCLIMB 800 WITH BMP 900 BIG BORE + FATT AZZ + Y-PIPE + 50MM THROTTLE BODIES
But its way over fueling.
There's another map, ARCTIC CAT 2010-11 CFR/M 800 WITH BMP 900 BIG BORE + FATT AZZ PIPE + Y-PIPE + 50MM THROTTLE BODIES that I haven't tried.
On the 2010-2011 map the fuel add percentages are WAY lower. I actually cant figure out why they'd even be different. A 2010 and 2014 motor are the same motor are they not? I'm worried about even trying this map as I don't want to lean this thing out and melt it down. (I have tried removing my PCV and running the sled for a few minutes, it rips, but it's running super lean)
I don't have an EGT or a AFR gauge so I cant determine if its running right except by feel and checking the plugs. (Which, on a proclimb is a HUGE pain in the ***)
I'm running the following kit, is there anyone else running the same with a map they can email me?
Here's the Bikeman kit I'm running:
- 900 Big Bore pistons and Jugs w/trail porting
- Bikeman head with low altitude inserts
- Y-pipe, Fatt-azz single pipe, powder lite can (all ceramic coated, idk if it make s a difference for the map required)
- Boyesson rage cages (M1000)
- 50mm Throttle bodies
- 2.5 degree advance timing key
- Torsional clutch kit 41/36 helix, Goldstar weights w/ 81 grams
Thanks everyone who read this.
