So I have an '02 Edge 800 and the other day it started running a little funny, but the temp light never came on. The next day it ran just fine for about 20 minutes in the powder and then it started acting up again. And then the temp light started lighting up unless I was on the throttle. It got worse and worse as I limped it back to the trailer. It wasn't melting snow on the tunnel and rear cooler like it should, so I assumed it was a broken pump belt. It sat in the trailer all weekend and when I started it up, the temp light immediately came on (like .05 seconds after it started!). It sputtered off the trailer and into the shop. So I tore into it.
Water pump belt.....Good.
Thermostat.......Good. I checked it in the sink with hot water and it opens up just fine.
Water pump impeller........Good. I thought maybe it was spinning on the shaft, but I put quite a bit of pressure and it won't budge, so I'm pretty sure that's not the problem.
Checked the coolant flow and it's flowing, but it just doesn't seem like a whole lot. At a high idle, how much should that thing be pumping???
And I have no idea why the temp light would come on right at startup. Any ideas???
Thanks for any help!
