J
JohnnyH
I just picked up a 08 700 155 with 600 mi for the wife and I am going through the sled and had a couple of questions.
Right now the sled is setup with 10-58's, Polaris almond(I think) 64/38-36 helix and a rep/pink spring and 2 derlins with 20-41 gearing.
We ride 7-10K and I am not too sure about the helix at all? Any thoughts?
When I pulled the primary clutch there was some oil in the clutch bore.
There was not any oil on the crank seal or around the belly pan or the underside of the clutch cover. I ran the engine and sprayed the crank seal with brake clean and the idle speed did not change.
Is the oil in there from the factory?
The air box has two big holes and two small holes in the top corners and when you look at them at a angle you can see that there was something mounted there at one time. . . . .Nitrous ???
I looked around and did not see any sings of a manual switch. Ideas?
Thanks All
Thanks All
