HELP needed on setup!
Hey all setup guru’s. Finally have enough snow to really ride.
I stand 5’10 go about 195lbs. Anyone have a base line on where I
Should start on shock pressure, ski position, on my 18 SP ER 162.
All help is definitely appreciated.
Thanks
Danny
60 in the fronts
65-75 in the center
125-130 in the rear
All on clicker 2 in the snow. Can use 1 on the trail to smooth it out a bit if it's rough
Sent from my ONEPLUS A5000 using Tapatalk
No they do not. They’re just float 3 in front, coil spring
In front of skid and float 3 on rear of skid. 50lbs on spindle shocks
Front skid shock spring is what rolled off show room floor setting,
Rear float 3 is at 120lbs
Thanks
Danny
How do u luke ur sled to handle?
Do u like a planted feel for serious hill climbing?
Do u jump a lot or big jumps?
Do u like a smooth ride on the trail and real tippy for boondocking?
[emoji12]
I hate the planted feel that cat recommends.
18 ER, for soft playful rolling side to side.
60- skis
1inch of threads- center
120- rear.
If u bottom out rear go up 5psi and try again.
[emoji12]
I am trying to improve my side hill abilities on this new sled after
ditching my 09 poo. Love to hill climb and boondock also. This sled is so much different than my other.
Thanks
Danny
Thanks
Danny
See my settings above
All shocks are the same but the center no? Crank the center so half the threads are showing below the spring. If the centers to loose the skis will feel glued to the snow.
No clickers and valving is different .
[emoji12]
