Help needed!! 2011 pro wont idle unless sidehilling
My 2011 pro 800 wont idle for somereason unless stuck on a hill or sidehilling.... ive replaced stator, tps, voltage regulator, ecu, etc and im stuck... I don't understand what it could be.... ??? maybe my fuel pump? tps is not out of place.
any help would be amazing!! BY THE WAY 200 MILES ON THE MOTOR....
Not sure how you side-hill at an idle. Are you saying if you tip it over in your garage it will idle?
it wont idle in your garage? if you put it on one ski in your garage will it idle? stock motor?
when I park my sled on a side of a hill up on one ski..... it will idle.
So, it'll idle when level? I assume you had to give it a bit to get the sled on that hill, but it won't idle when you start it up for the day? Have you replaced the fuel filter recently?
Have you checked fuel pump pressure and the voltage going to the pump . Check to make sure your injector wires are secure and not rubbing.
