R
riceburner
Hey gang - need your help. I am heading west in 3 weeks and I have a 2000 MM700 with trips, ported, and a boost bottle. In preparation for my trip, I took off the carbs, cleaned them all out, jetted it, etc. I hooked everything back up and she fired up just fine.
However, I noticed a decent amount of gas leaking out the bottom of the sled, on the pto side. I am sure this has been happening for some time as I have noticed it in the past when I stop - and when I leave, the snow is greenish from gas / oil mixture.
What are your thoughts? I know I hooked up all the gas lines to carbs right. What else could it be? Do other lines run out of the fuel pump that could be causing this? Any ideas / thoughts are appreciated.
The sled ideled just fine - just looking to track this leak down. I also did a pressure test on cylinders - 127 across.
Thanks.
Jon
Thanks.
Jon
