Is there a maximum amount of accessories you can run on a m7 without overloading the stator. Can it be changed to a larger one???
I know a 4amp draw will put it into limp mode.
I want to run egt gauges, boondocker and still plug in my gps
its all depends on where you wire each in. The only true dc connection is the fuel pump wiring, it cant handle much amperage but should be fine for one of those. and you can have your stator rewound for a little more output. maybe a capacitor setup like the turbos to power both as well
i have a tm7 with egt's,a/f ect and i think the fuel pump is ac, the rest of the power is dc.u should b fine, u might have to run a capacitor?hope this helps
