I have a enclosed trailer, I have installed a JVC car stereo, connected ground to body frame of trailer, front speakers, and antenna. problem I am not sure about is for power there is a yellow wire which says to hook it up to a live wire which I have done, I have not hooked up the red wire which is said to go through the ignition switch on a car (which I do not have).
My question if someone can help me is when I hook up the power on the unit it turns on for about 5 seconds than turns off and I cannot get anything to turn on after that, Do I need to connect the red wire for ignition directly to the power source also with the yellow or just the red wire ? also I would like to run a inline fuse what size would you recommend.
Thanks
Thanks
