Help Help Polaris 2007 600 rmk dash lights stay on when sled is off
Sled has the dash lights illuminating when sled is off. Unpluged key and it stayed on. shuts off if I unplug wire by battery that goes to a little relay type thing. so I replaced it and it still stays on. sled has electric start. Only non stock thing on sled is a led brake light. Not sure why gauges stay lit when sled is turned off. Help Wayne:light: really need help on why lights come on and stay on any one else have this happen.
That would be the starter solenoid on top of the battery. The only thing I can think of is that there is a short somewhere in the wiring or the regulator is faulty and is letting the DC voltage from the battery feed back into the AC lighting circuit. Try disconnecting the regulator connectors to see if you can isolate the problem.
