I've got an 07 M8. Changed the DD oil this fall and have been riding quite a bit with no issues or funny sounds. After a ride this week, I went to inspect my sled and noticed a thin film of DD oil almost everywhere on that side of my sled. Drain plug is tight, fill plug is tight. On the secondary I noticed that DD oil had been spun outward from the bolt that holds it in the shaft. I have removed the secondary and don't notice any play on the input shaft. I thought for sure that I would have play in the input shaft which meant the bearing was blown. I'm at a loss right now.
Does the oil mean a bearing has lost one of its seals and is on its way out?
Is there a seal (not in a bearing) in the case that is blown and needs to be replaced?
Both?
Thanks in advance for the help,
Trevor
Both?
Trevor
