Help, Dragon not running
I have d-8 that ran good until the other day. It just died, had spark, and no signs of engine failure. I then unplugged the pc-5 and hooked the ecu up without it, it now starts, but only ran right for a very short time. Now acts like it is limp mode with no warning lights coming on and no codes in the computer. Anybody seen this or have any ideas?
my 09 d8 350 miles on it 60 miles on update stalled today after half a mile started got it home idles about 1100 rpm but will rev up to get it on the trailer. had the latest flash monday. does this sound like a vr problem?
What do your plugs look like? If they are lean, I'd pull the ex. valves to look at the pistons.
plugs are brown look like good coloring never seen any det light or anything else
just started acting up. goes to the dealer on tues . might pull ex valves and have a look.
The power source for the full load injectors coming out of the ecu is what powers the pcv I believe, and the circuit inside the ecu failed not allowing the pcv or the injectors enough power to operate properly. My bet is the vr failed and sent a voltage spike and burned up the ecu. Hopefully it didn't take out the pcv too. Won't know that till my new parts come in.
