HELP: Coolant In Head Spill
snowboatboy
New member
As I was putting was putting all the electrical stuff back on my engine I realized as I was putting the temp sensor on the bottom of the head that I couldn't get it back on cause the bolt was to long to fit between the cylinder nut and the head. so i pulled all the head bolts to put it in, but I forgot that I had already filled every thing with coolant so when i pulled the head a bunch of coolant spilled and I assume went down into the engine. what do i do i'm freaking out because my motor is all freshly rebuilt and I don't want to ruin it and have to do it again. Its a 07 600 HO. THANKS
You have to pull your head and cylinders to get a small tube connectected to a shop vac down there to suck it out if you are worried about it
yes that will also work, I always make sure to suck it all out of the case while doing top end rebuilds. glad you figured it out
