Help - Battery or something else?
Bigrock33
A year ago, having the Apex (w/ SC) serviced, I was told the battery was bad, so I had it replaced. It worked fine the remainder of last season, was fine the first rides of this season until last Saturday. It was completely dead when I went to pull it off trailer and ride. Thought that I must have left the key on as I had been working on getting the control box dialed in during that week. Jump started it, it started right up, never had a problem with it the rest of the day, stopping and starting quite a few times. Went out today to do a little work on it, completely dead. Have had the charger on it for a few hours and still completely dead. Am i just having bad batteries or is something causing a drain? If I need to replace it, what would you suggest. Thanks for all the info, advice.
the easiest way to check for a draw is to disconnect the neg. cable
from the battery. Then with your test light, connect the clip to the neg post and the probe to the neg cable terminal. If it lights up you have a draw!! If it doesn't, no draw!!
If I need to replace the battery, what are the recommendations? Currently have a Yuasa. What features are most important?
