That is before clutch engagement... The clutch setup is designed to engage at 3800 RPM.
Have you compared it side by side with other 2013 PRO 800 RMK's??
How much time do you spend with your hands on the bars below clutch engagement?
Mine vibrates like a mofo from like 2500-4500 rpm. i know some of it is becuase i went with Boost-it motor mounts but my god. Wife actually told me today she couldnt ride my sled very long or she would have an orgasm
Take it back to the dealer if your side by side comparison is different....
But first...
If you can get your buddies to work with you... try swapping out the primary clutch and see if that changes it... if so.... have the dealer warranty the clutch.
I don't think that would be a good idea.Is this a known problem? I could just pop mine off and rev it up. Might try it out
Shouldnt matter. Not hitting max rpms or anything. Clutch isnt going to do anything specialI don't think that would be a good idea.
It may have a clutch out of balance but don't start it and rev it up without one on it.
D
yes it does matter. Don't run your engine without the clutch on it![]()
