Help 2010 Dragon800 163
I have a 2010 dragon 800 163 and had to tow out a m1000 out in very deep snow no problems. Got back to the truck then had to load the broken sled into enclosed trailor. Pulled broken sled into the trailer and i looked down at my temp and it was about 200 then once out of the trailer it started cooling down. Was wondering if that temp could have done any damage to my sled. Road it back to my trailer and seemed to run fine. Just wondering if i should be worried or not. If so what should i look for.Has never been hotter than 125 tell then.
D9, I have seen these sleds about that hot a few times with out any serious issues but check your coolant level in the coolant jug and if it is ok and if no coolant was pushed out and the level is ok you should be fine. I would keep a close eye on it for a while though. You must of been on mostly hard pack when you pulled the other sled to your trailer I would imagine for it to get that hot with out the scratchers down?
Yea had to drag it about a mile down from the parking lot to there trailer. Coolant is still full and didnt see a check engine light at all. So i will just keep a eye on it . Thanks for the help.
