I finally found some time to dig this thing out and work on it a bit. First thing I did was put a small 12 volt battery directly to the fuel pump using the red wire for positive and black for ground. The pump kicked on and ran just fine, I tried to start it with the battery still hooked up and it did the same thing as before. Started up ran for 1-2 seconds then died...
I noticed the black wire coming off the fuel pump had a red stripe on it so i swapped them around using the black/red wire for the hot wire and the red wire for ground and it fired first pull idled and ran like a new one! I then cut the wires thinking it had been wired backwards plunged it back in with out the battery and it started up ran for 5-6 seconds and died, now its back to running for 1-2 seconds then dies.Its almost like it isn't running the pump fast enough..??
Keep in mind it had a push turbo set up, and I'm trying to put it back to stock. I need to sell this thing but want it to be right first! any help would be greatly appreciated!!
Thanks! Michael
