First off the sled threw code 1-6. Adjusted power valve cables tested servo motor could not figure out what was causing it. I installed STM valves code went away but now it has an intermittent miss. It happens about every 7-10 seconds while on the throttle. here is what I have done so far TSS is already deleted. I have dielectric greased every connector removed tank inspected every wire under the tank the only thing I see is the PTO side coils both wires are flattened not rubbed through though and I still have spark during spark test. I also tried to disconnect the brake light. I have inspected the injector wires and no issues with those either.
