On my last ride a couple weeks ago, my M7 seemed to back-firing quite a bit and want to die at low r's. It did die at idle a couple times but always started right back up. Now all I get is one pop, and then nothing until I dry the plugs off and pull th rope again. I can get it to fire, but won't start.
It has spark, and its getting fuel because my plugs are wet. I checked my fuel pump with a 12V battery and it runs forward and reverse- no clicking, so I think the fuel pump is ok. I haven't checked my fuel pressure, may not have enough pressure.
Does the fuel pump have multiple "smart valves", and one of those is closed?
Could it be an injector failure?
I should add that I am running a RKT 800 kit with a boondocker box.
