helix help
Transporter
Just trying to figure out whats in this machine.Primary looks like a blue silver blue not blue white blue and is that the arctic cat purple seconday?Is it the same as Alpines black?Also does anybody know what helix that is?Also in the first picture should I be worried it looks like a casting flaw or something on the turbo.
turbo is fine thats normal, cat purple is the same as alpine black, can,t tell if it is silver or white in the pic, but if it looks like silver then it most likely is, looks like an after market helix can,t tell what the angle is from the markings, look on the inside alot of times they will be marked on the flat section between the ramps. not sure on the rollers and wieghts.
How does the blue silver compare to blue white or blue pink springs the weights are supertips not sure on the rollers.Found a 51 on the side of one of the ramps.
b-p-b is 30-90 ,b-s-b is 35-101, b-w-b is 45-111, if it says 51 I would guess thats what it is it looks fairly steep, looks like your set up fairlyy well, make sure you keep plenty of belt pressure with that helix, check your rollers I would run 14.5,s if they are not already in it. 15.0 will work but I wouldn,t run any bigger than that you need all the bite on the belt you can get.
