R
ROX SpeedFX new Height Adjustable risers will be available soon!
I thought that I would give the members of SnoWest a sneak peak.
We are waiting to put these on-line until next week because we are waiting for the hardware that is being dry-lube coated.
This new design will allow more flexibility in mounting and more range of adjustment.
We have the new 6”-9” and a 4.25”-7”.
Both will clamp 7/8” or 1-1/8” bars (when 7/8” reducer is removed).
2-tone anodized finish.
Hardware is dry-lube coated for consistent torque and hassle-free adjustability.
Wrenchless lever kits are available as well for on-the-fly height adjustment without tools
Both of these new H/A Risers also come with 1” limit stops (viewable in photos) that can be removed. Making the 6-9 a 6-8 and the 4.25-7 a 4.25-6. This way you may be able to safely use the risers if your cables are not long enough to use the max height but have enough cable for the 1” lower height. The stops can be removed once you have adequate cable for the full extended rise or reversed to limit how far they are lowered. Some sleds may be able to use the full height without extending cables.
Perfect for the ride home when you are sitting down and don’t want to have the bars so high but still like them at the proper height for standup, active use.
Also great for rental fleets or the backup sled that will get used by many riders.
Thanks for looking.
Rox 6”-9” Height Adjustable Elite Series Riser
Rox 4.25”-7” Height Adjustable Elite Series Riser
![2.jpg 2.jpg](https://www.snowest.com/forum/data/attachments/68/68388-3f16edcbaf7b797ce66d9f52b77701ba.jpg)
Thanks for looking.
![1.jpg 1.jpg](https://www.snowest.com/forum/data/attachments/68/68377-5749af7904fa7163428c4d465e895ad0.jpg)
