Eric is correct and I would suggest the Air pro or fork spring for sure to start, then adjust your forks in the triple clamps. Easy to do when you are out riding. Move forks up (more stick out at the top) and you will reduce ski pressure. Try 1/8” at a time. The difference is significant, even with small changes and don’t be afraid to go up 3/4” if that achieves the ski pressures you want.
To build on Eric’s post, consider that with the length and width of the track under a snowbike, in most instances the track will try and remain flat on the snow as you ride. Picturing this on a packed road, when you roll on the throttle, the track grabs traction and propels the bike forward on the track. It’s going to try and plant the track flat against the snow for maximum grip. What this means in your static setup is that if your track is raised slightly in the back, the weight will transfer back during forward acceleration to a “flat track” position and your ski will tend to lessen its ground pressure because the bike has rocked back onto the raised rails.
If the track is flat to start with it will remain flat, and ski pressure will be greater.
If you actually lowered the rear of your skid below flat at the back (longer strut rod) you will have even higher ski pressure as your track tries to “get flat” to get traction and drives the ski down in the process.
Raising your front skid shock pressure or spring preload lifts the center of the bike and does reduce ski pressure but does less to influence weight transfer. Softening rear shock preload will assist weight transfer and lessen ski pressure under acceleration only.
Does this make sense? It’s all about allowing or enabling weight transfer to the rear. I find that strut rod adjustments will affect ski pressure most during acceleration, climbing, etc.
Now, having said all this about the skid, strut and rear shocks, what else?
Well that’s where the fork position comes in.
Let’s assume you have a flat or slightly raised in the rear orientation for the track. The ski pressure that is felt as you ride with this setup is set. Keeping the thought in mind that the track stays flat to the ground as you ride, imagine if you raise the forks in the clamps. It will, in essence, “ lift” the ski up towards the bars which will reduce the riding ski pressure. This is most prevalent during cruising because remember, if you accelerate hard you transfer weight back by default and your ski pressure goes away. But if you are not accelerating hard and are just cruising, raising or lowering your forks will change the “set” ski pressure.
You will find as I said these fork adjustments are significant and you really feel them in the steering.
I generally ride with my rails slightly raised in the back, about 1/2” over the length of the rails. Then I set fork position to get the ideal ski pressure.
I hope this makes sense and helps. I have ridden bikes that are off and ones that are dialed and the difference in the riding experience is so drastic that I’m afraid that there has been more than one rider that got completely turned off of snowbiking because he rode a poorly setup bike.
All these effects lessen greatly when you get in the powder but if you have to ride any trails or hardpacked snow to get to your riding, that’s where this setup pays off big.
There may be plenty of other opinions about this but this is my experience.
