Heavy Hitter weights???
Has anyone tried the Heavy Hitter weights with the tip loaded? The advantage I have seen with these weights is the amount of squeeze on he belt in the initial stages of the shift. The other advantage is the ability to place the weight in the cam arm to match the load requirements. Example ..you can add weight to the mid to put the initial stages of boost and power to the ground. Any advice?? Any experience?
