head shim and valve timing
Anyone have instructions on doing this. I have removed the head and installed the shim the way powderlites instructions say but I am a little confused on the valve timing part. If anyone has some more precise instructions or input that would be great. I have kept all the pieces seperate so i can put them back exactly where they came from but should I have marked witch side of the cams was facing up or will it only go one way. I had it at tdc when I removed them. Also when I took the last bolt out of the cam gears the cams rolled one way very slightly. Is this normal? This is on an 08 nytro.
Thanks.
