Head light cover!
What do you mean by cover? ArcticFX Graphics does headlight covers that are part of their wraps. You can buy individually. They have small holes so the light still goes through but you can see the wrap design.
any one know where i can get a headlight removal kit that isn't 300 dollars? just a plate to put in there so it saves weight?
Mountain Fit Hoods....ran the first production ones a couple weeks ago, i am not sure if they made the site yet but give Bill a call, he is doing them in vented and solid, dont quote me but i believe at 150 vanted and around 80 for the solid....
If you are on a tight budget.. you can cut the back off the stock headlight... paint it black inside with plastic paint and glue it in place with some good clear urethane sealant/adhesive like "Big Stretch".
Make sure to put a resistor on the headlight circuit after you remove it so you dont damage the electrical system... some have done it without damage... but why risk it...some HAVE done damage befere they went to the resistor.
thank you very much, those hoods are heavy, i took mine off yesterday to take the foam out.
