Coolant
Shouldn't be a problem, soak it up with a rag. Not sure if the 06 had drain plugs in the bottom of the case or not, if it does you can remove them and drain it. Maybe flush with a little premix. If you have the cylinder off, squirt some injector oil down on the bearings and around the crank pin bearing. It will smoke when you start it but who cares.
