HCR rear Shock PSI
jakey-boy
Tried to run a search but couldnt find anything specific. What PSI do you guys run on the rear shock for different rider weights? Thanks if anyone has some info
hey
I run 150 psi in float, and had the pressure increased on front track shock this year also. Make sure to check fluid in float often to maintain performance. I'm 230, ride her hard, and she bottomed out last year all the time. Its a whole different story with current set-up, no bottoming out.
i barely load the front skid shock, I increased pressure on it last year and the more I put to it the worse it trenched. Bottomed out a lot last year but had holz do some valving and a double stack spring in the front, no time on it yet.
im 160 lbs and tried a bunch of psi until i rode a buddys sled and had to know what he had supprised to find he had 122 lbs it works soooo well also run the limiters on the tightest holes rides like a caddy now and good steering minimal trenches
