HCR M8 piston scrub.....
Backcountry Bandit
anyone with one or if you know someone with one have them pull their pipe and inspect their pistons. out of the 4 HCR's sold here 2 have blown with the exact scoring on the pistons..(egg shape) they both had under 90 miles. hopefully this is just an iscolated case for mine is A-ok. these sleds are effin deadly! so happy with it.
just a friendly caution. would rather see the problem then have to be towed out of the tains....
i have two HCRs with 200-300 miles each.. no problems. thanks for the heads up
you took your pipe off and checked? the one sled still ran strong didnt seize.....it was a matter of a ride or two. the other died. i hope everything is well with yours! how do you like them? i cant get over how quick they are. has your seat softened up a bit now with that many miles? my seat is starting to but holy **** its stiff.....thinking of gel inserts or something. take care!
i really hope its just these 2 sleds! thses things are so impressive wouldnt want to tarnish that!
Lean through the mid range. if you run at 1/4-3/4 throttle you probably will burn them down. On the throttle or off, thats how they need to be ridden...
300+ miles on mine... but i have heard of a few others burning down
