HCR 4 wheel kit question
08 is a 136 right? You have the small wheels so I guess you could cut your axle down and drill and tap it and put the four wheels you have on the inside.
The center spacer on the HCR is 1.467" and the two outer spacers are .984".
I have a 08 Crossfire 8. Im trying to find a rear wheel kit like the four wheel kit on the HCR. Does anyone make one yet?
problem is the crossfire has 136 rails with 6.38" wheel size and the hcr has 153 rails with 8" wheel size so they are NOT gonna fit with 136 rails.the best you can do is get 141 rails/track/susp. like the 2009-2010 CF's and then the 8" wheels will fit.
another route is an offset axle.which run the 6.38" wheel on the inside and 8" wheel on the outside.its available(i'm not a big fan of this though) go over to HCS(hardcore sledder)or arctic chat and do a search tons of info.good luck
