having an issue with my pro
I have a 2012 pro with a boondocker turbo. I just bought it and only had one good weekend riding it. All of a sudden it started acting up. When in low rmps like 4500 it will pretty much die and the air fuel gage will go way up. if I put it up on the stand and slowly add throttle it will lean right out as soon as the track starts spinning. I had it all apart all the hoses and connections look good. I can get it into the higher rpms and it runs fine there. 500 miles on the turbo kit and it has ran fine until now. Any suggestions? thanks
I have had problems with the injector wire have had to take it out of the harness and solder it together. Also check you fuel filter. Mine has done the same thing.
