Has anyone installed a water/air intercooler with a boondocker m8?
Ken Climb
If so, did you convert boondockers air intercooler into water or did you use the frozen boost intercooler.
I here some peeps are using there engine coolant through these intercoolers.
I'm not interested in that app.
I'm talking about a separate cooling system using a heat exchanger in the tunnel and running it through a water/ air cooler to coolcharge temps.
I'm hearing about charge temps of 65 deg F after a long run then going down to 45 deg within a very short time.
Are these claims correct? If so Any negatives other then maybe a little more weight?
