harder to start
B
bustamove
So lately the sleds been taking more and more pulls to start cold. I slow pull 3 times then takes about 8 to 10 cold. And about 3 from warm to hot restart. When it's cold it has a rough idle until it gets a few degrees into the motor. Or blip throttle
Stator has been replaced showing almost full bars.
Compression was at 120 start of season going to re check
Tps has been reset recently
After doing research on this forum. I've got a few things to check tmr in garage.
Chassis relay, probs replace
And capacitor
My question is there anything eles I should check out while I'm in there?
And capacitor
Fuel Filter, fuel pump. Sounds like the pressure is bleeding off and isn't at the rail when you go to fire it up.
