Hard Starting
Quick question for the forum. I have an 05 600 Summit Rev, and it just wont start when its cold. It used to start great, now I am lucky to even get it to start if it has been shut off for a few hours, and its around 10 degrees or so. Everything else runs and works fine. Any ideas on where to start to fix this problem?
Make sure that you have fresh gas through the carbs and run it for a while. If it is still hard to start then check your choke cable and make sure that it is fully engageing when at full choke. If this does not help then you may have ring issues...I had the same problem. When they get hard to start then it is usually rings.
