My 02 700 is hard to start sometimes. For example, today it took pull after pull to get going after getting the sled unstuck on a small hill. This was the only time it took that long to get going but even when stopping for a break and starting back up it takes 5-10 pulls sometimes. I've heard there is a diaphragm in the carbs that can go bad and will cause hard starting, but you can tell if it is bad if there are bubbles forming where the line goes into the carb when the engine is being turned over. No bubbles in mine. Also wondering about the on/off valve that is inline with a small coolant hose leading into the carbs, might this have something to do with the hard starting and what difference does it make being on or off. Thanks
