R
I'm going to upgrade my handlebars to some CFR bars. I currently have a set of Mid bars on my 2022 Matryx Pro RMK and want to go lower. I also have a 2013 Pro rmk that has taller bars around 7" high. my question has to do with hand warmer compatibility between the 2022 and 2013. can I just simply swap my mid bars off my matryx over to the 2013 Pro rmk and should be plug and play? or is there going to be an issue with warmers. also wondering if the older 2013 pro rmk warmers could/should work with the 2022 matryx if i cut them off and use them on my new cfr bars.
trying to avoid cutting/peeling off both sets of warmers if i don't have to but may end up doing so. Just thought i would post and see what you all think. at $100 a pair of warmers a set it gets expensive quick esp since these ones already work fine.
