handle bars i need help!!!
R
rmking600
i need at least 8 inch risers and extentions for the kill switch light switch hand warmers throttle cable and brake lines on the 96 xlt rmk were do i get all of those the curent bars are stock and im a big guy so i need them taller
Extension
I don't know of anyone that makes a wiring extension. If you need a lot them you will have to splice each individual wire. Solder and heat shrink tubing. I would splice between the plugs and the switches, not in the main harness.
Longer throttle cables are available from SLP among others, same with brake line or you can fab an extention yourself on that.
