Seems like things on the forum are slowing down a bit - most of the new products and mods have already been discussed.
Just to kick things in gear a little I thought that people may want to see the different ways Nytro owners have modified their bars and risers.
Mine is pretty basic - I added a 2" inch block and then added a Rox pivot riser to get the bars a bit higher and forward.
I received a Goldfinger left-hand throttle as a gift and installed it. It has yet to be used so I may take it off. My first pair of bars were broken so I upgraded the grip heaters when I replaced them (stock bars).
Also mounted my SPOT device on the post. The unit's logo needs to be facing the sky and this was the only place I could find that worked (I like using the tracking feature so it's on most of the time).
The guards are from Rox. I had to use the Yamaha mounting brackets. The Rox mounts wouldn't work. It took a little bit of plastic alteration (grinding) to get the Yami's to fit but I like the end result.
Interested to see and hear what others have done and what the results were.
