Hallman boost control install ?
sledheadd
I'm installing a HBC on my nytro and I am looking for suggestions and pictures if possible on where to locate it.
I do have the remote kit to do adjustments on the handlebars so no need for the HBC to be easy access. I was thinking of mounting it just behind the wastegate (MCX)
Thanks in advance
If you have the billet knob, the fitting on the end of the knob is the line to the turbo. behind that fitting is your ball and spring. The fitting coning out of the side with the little hole in the fitting goes to the waste gate actuator. You can mount it any where you want, but I would mount it accessible if you change your riding elevations and have some self control.
the install on mine was easy. it came with all the necessary instructions. the remote knob worked good too, i have it mounted on the 'guage cluster' next to my boost guage, easy to get to but out of harms way/ accidental turning.
