The Enduro Engineering light kit I have pull power directly from the stator. I'm guessing so that the bike has to be running to get power. Wouldn't this be advisable for the grip heaters as well? I know a relay will serve same function but more splicing required with that option. Thoughts?
If you spray foam the inside of your handle bars it helps to keep some heat in your grips instead of it all being soaked into the aluminum
Typ relays are not used in Ac powered applications. Yes the bike has to be running for ac powered products.
On battery powered grips a relay can be used to auto turn off the grips when the bike is not running, No need for a relay in the ac powered product.
I am more concerned that the circuit that is fed off of the stator (I bought an upgraded stator) will not be adequate to run both the headlight and grips. Thoughts?
2013 450 XCF. EE stock replica 35W headlight and Trailtech 100W stator. Heat Demon grip heaters. Not sure what else is on that stator circuit but I'm guessing if the stator can supply the 100W power no reason I can't run at least 100W through that circuit. Perhaps I answered my own question... Lol
