Grinding 10-70's
200smk
Hi Guys,
Just wondering the best approach to grind a set of 10-70's down to 10-69.....
I'm right around the 2000ft mark for the majority of my riding......the info I've read here suggests that 10-69 is an 'ideal' spot for a factory set-up.
Thanks.
grinding block so they are all the same on a belt sander ,, then ,grahm scale to check,,, and fine grind to balance
What spring are you running.. a slightly stiffer rate will Could have the same effect.
Stock Spring.....
Would I be grinding in the heel? or across the whole backside? I know to ensure that each are done the same.
ON the EDGE... like how that weight is laying on the table.. on the EDGE..
So it is even.. coming off..
In the primary right. Would that give you more max rmps. I have a new slp blue/pink in the drawer. I think it is alittle stiffer but dont know for sure sence slp and polaris are measured at different rates.
Anyone know. Thanks
