Did anybody get the new guage with the GPS in it? Any opinions on it? Just curious, have not heard much comment on it.
Does it track where you have been?
You don't have to push the accept button.. disclaimer goes away automaticallyReally like mine as well, but hate to have to push the "accept" button every time I start up. Is there a way to clear the disclaimer?
Any details on your battery set up?Really like it, easier to read, GPS has helped explore new areas. I did hook up a small battery. For updates and changing settings without the sled running. I could live without it, but it is a nice feature
Is battery/es required for operation
Sent from my SM-G900V using Tapatalk
ES harness from Polaris #2413091, $99.99 list price. This is on back order but I still got mine within two weeks of ordering. Seems like a lot to pay..... but it does complete the charge circuit has a inline 2amp mini blade fuse and no guessing on schematics!
The main plug in left side of photo plugs into factory harness above brake caliper. The red wire top of photo with male bullet connector connects to the battery positive (red wire). The brown wire in bottom of photo with eyelet connects to battery negative (black wire) and I also ran a ground wire to chassis. You will have to match connectors of you choice on the battery leads to the harness positive and negative wires.
Trail Tech 12V 3700mAh NiMH Battery 20 oz $59.95 (I had it leftover from a dirt bike project)
Trail tech Battery Bag & mount$19.95
I used the existing thread inserts on the back side of the foot stirrup to secure the trail tech mount and added a third bolt lower into the foot well kick plate (obviously, do not leave a bolt protruding into the battery or your foot)
The battery needs a full charge before use!
Zip tie harness and wires up tight and ready to go! No rebooting when going into reverse, easier to learn the gauge functions with out running the motor, updates etc. It works well
