Good index finger throttle option
kidwoo
I wasn't too happy with the swing of the stock thumb throttle flipped so I screwed around with a few different options. A goldfinger doesn't have enough cable pull, the mountainbike levers I tried kind of sketched me out with all the open space and potentially sticky aluminum. I never got a watercraft finger throttle just because it's as big as the sled one but with potential compatibility problems with kill/reverse switch space.
A buddy had one of these
http://www.leftythrottle.com/
I'm not sure but it might be the same block as the powermadd one.
I had to put in some riser spacers to get it on a 7/8 bar but those are easy to find.
But the cable pull is perfect. Just a tad bit of slack at rest and I top out the throttle body stops like 1mm before it hits the grip. The stock ball end fits right into it too.
And the paddle is like 1/3 the size of the stock thumb one. Feels awesome with one or two fingers.
Got a Polaris clutch and a skidoo riser....probably going to have some Polaris skis on there soon. I keep thinking about what I can put on there from Yamaha but a sticker is the only thing they make that won't be a downgrade.
You should try one of those dtc throttle blocks. It's like it was pretty much made for this. So much better and smaller than a flipped regular paddle.
Well technically it IS still a thumb thingy. I'm just using it incorrectly. And by incorrectly I mean "in a superior manner"
Driving me nuts not being able to ride yet. I may have to get road trippy soon.
I have seen a couple riders that flipped the throttle around... what exactly is the benefit? Better throttle control?
When you get waaayyyy over to one side of your sled, your wrists (and hence the base of your thumb) moves. Your index finger pretty much stays put no matter where you are. For the last few years I've run my throttle block loose so I can rotate it either way. The only time I want it 'traditional' is when I'm sittin on me arse cruising a boring road to somewhere.
It just tires your hand out a lot less too. I mountainbike all summer so my booger pickin finger is in good shape from using brakes. I don't know what it's like for everyone else but I definitely prefer it.
Also when you fall off your sled and that beast comes rolling at you, your track doesn't keep revving up from a thumb throttle hitting the snow.
http://kidwoo.com/FT2.JPG
let's see, red button's obviously kill switch, yellow button's reverse ? who makes those ?
what'd ya shim the throttle body with, cut down a 25.4/31.6 handlebar shim ?
i really like that setup, just might have to try it - bars, flat bars or risers ?
Got it right on the switches. They're both RSI pieces. I think fly makes some too and they look like the same thing. I tried REAAAALLLYY hard to keep the stock throttle body block but even with the paddle removed it just takes up so much damn space. I could have cut it but I wanted to leave it in one piece for when I sell it.
Dealing with the switches was kind of a pain in the as$. If you look at the first pic you can see where I had to file some grooves in them for the grip heater wires and then the kill switch wire to get past the reverse switch.
The reducers just came from some fly risers I took off. You can even buy them individually from most people that make bar risers. To be honest you could also just cut some of your grips and use that for a spacer. I wanted a rigid interface though.
The bars are just rsi flat chromo bars. That's actually the real reason I did all this shlt. I wanted some bars with less sweep to cut down on that elbow ribbing steeze that everyone gets when sidehilling an M-sled (or any sled with bars with a lot of sweep). Plus a flat bar lets you use the skidoo risers that have the greatest amount of adjustment.
  • Like
Reactions: K2
thanks again ..
I've got a spare pair of Bonz barkbuster mounts off one of my KTM's that I wished the bolt clamp pattern was the same as the sled's - with the finger throttle they're ( the barkbusters ) obviously mandatory
I'll be honest I'm not entirely sure that barkbusters are 'mandatory' with a finger throttle. You won't end up mounting it horizontally, it actually points more down than forward. Obviously it could get hung up in some branches or snow but I rode with a flipped throttle on my last sled without guards of any kind and never killed it/myself. Not a bad idea but probably not as essential as you think.
I run handguards for a lot of reasons that are just as important as the finger throttle thing. They're great windbreakers at 7am and I'm VERY well programmed to auger through some branches to stick a line from riding bikes. I've got those things on for my knuckles as much as anything. But yeah, they're probably not a bad idea with the flipped paddle. From what I've seen of a lot of the riding in AK, it's pretty easy to get away from trees ;)
Those bonz mounts might work on a riser though. You could get a t-top post or one of those adapter things for the top of your flat top post.
good insight ..
and that's a fact, treeline here is low altitude for sure
looks like another project while waitin' for more snow - to me the thumb paddle throttle on sleds just ain't that ergonomic ...
ha, just installed my CSP T Top post last weekend combined with the Skidoo riser - haven't gone out and checked the bolt pattern on those clamps, just compared them to the stock adjustable Cat post laying next to me - soon to hit Craigs list ..
Interesting...I may have to look into that. I do know getting way over off the right, it's hard to use the thumb throttle and that's why I installed one of those throttle flares by SnoBunje so I can use my fingers to grab the throttle. Is this a hard mod at all?
loosen two torx bolts, spin throttle. On a stock cat, just be careful to go slow and don't hurt the heater wire. sometimes I cut the edge of the grip back a bit so the wire can move a bit more.
Btw, without a handguard, you just keep the middle finger behind the throttle as you hit a tree... that way if it hits the throttle, it's no big deal, and you're still in control. I currently don't have handguards on my 13. Obviously I'd prefer to have them though.
Took the lower rise 22.2 clamp riser back to the Skidoo dealer and swapped it for the even lower rise 31.8 riser and the Bonz top clamp/bark buster booted right up :face-icon-small-hap
now all's I need is a Lefty's and a couple of RSI switches and I'll be good to go :face-icon-small-ton
also sprung for one of these too in a no-rise 760mm width with 10 degree sweep >>> CUSTOM "DH" HEAVY-DUTY HANDLEBAR, CUSTOM WIDTH & BEND, THICKWALL TITANIUM
This is a THICKWALL HEAVY-DUTY handlebar of any length up to 32" wide. Intended for Downhill/Freeride mountain biking or any other non-standard, heavyweight applications. For lightweight, shorter thinwall bars see above.
* 7/8" thickwall, 3/2.5 alloy titanium handlebar.
* Custom made with a thicker wall for heavy-duty MTB application in any width or bend up to 32 inches.
* Bead blast finish standard. Brushed finish available ($20 upcharge).
* Weight is approximately 13-oz / 0.369-kg at 32" length.
* Includes aluminum 25.4mm OR 31.8mm stem clamp shim.
* No inserts required for bar ends.
* After you purchase this item specify the length and bend angle in the Paypal Comment box.
$165
FINISH + SHIM SIZE
SPECIFY WIDTH & BEND
hope it holds up :face-icon-small-win
