Goggle bag install help!
C
cbc24
Hey i just got a 12 assault and purchased the underhood goggle bag , how do you install it? it didn't come with instructions
One corner hole uses the plastic rivet that joins the hood and cowling, the bolt goes to another corner and a hole in the hood. The rod slides in a sleeve in the bag, over the aluminum spar, using the rubber piece to prevent wear. The other rod end goes in a hole in the other spar, and the hook goes in a hole farther forward in the closest spar.
Nice bag but they don't keep your goggles dry, too much steam from snow to pipe when your bashing snow. Great for food though.
Thanks!! but I figured it out shortly after ripping the hood off. Got tether, and all the bags on. Just mad because i thought the snowest decal pack would be better than the chincy material its made out of, I was going to be creative and wrap my windshield with the whole roll , or a vinyl i had made but i failed at both and destroyed the trim on my brand new shorty windsheild........
I want c&a xtx skis , ggb can, and some venting next. But in time.
on the 2013 there are no holes drilled on the carbon support arms to slide the tiny plastic rod from the bag into
The rod is not needed on the 2012's. With the hook that goes toward the front of the sled the hole is on the inside of the tube on the 2013's instead of the outside like the earlier models.
I just zip tied the rod on my 2013. Bigger issue was the wiring harness, it completely interferes with the bag.
Zipped tied to what? I don't think the rod gets used on the 2013 with the hook system there
