Glasspack RX-1
I'm thinking of just putting a glasspack under the tunnel on a SC'd RX-1 I'm building. Can anybody that's done this give me the dimensions I need on the glasspack? There's lots of them on e-bay, but beeing in Norway, I do not want to order one that will not fit.
Thanks, Bull
thanks, I'll check it out..can you tell me how loud it is? I really like my sleds quiet, but I'm willing to sacrifice quiet, by not having to spend $500 on a excell exhaust...
on the rx-1, did you cut the stock pipe right where it goes from 2-1? Is a 2" somewhat the same as the stock pipe? (I know it's flat right there, but)
It's got a pretty good bark to it. The longer 2" diameter glass pack is a little quieter but not much. I wear earplugs on my turbo with the tunnel dump so this isn't as loud as that but I should likely wear plugs on the Nytro as well. In deep snow its actually fairly subdued.
M5
I found a pic of my old Rx1 setup before I turboed it. Just dont put on the trun down as it will hit your track. As for the running boards, both of those are tunnels I built myself.
Does you exhaust dump in front in the tunnel now with the turbo? If it is, how's the sound difference on that against a glasspack? MUCH louder?
