Geo Mod question on KK
I've got an '05 KK but I put in the 2009 rear skid and I've also done the BDX tunnel/running board mod as well. I want to do the Geo mod to help the ride.
The holes that I'm supposed to drill on the rails make perfect sense. However, the new holes that I'm supposed to drill in the upper suspension mounting brackets don't make sense. Here's why... My mounting brackets are mounted in the opposite direction as what is shown in Elvis' post - (http://www.snowestonline.com/forum/showthread.php?t=213616)
For example, in his first picture in the link above, the two predrilled mounting holes are towards the rear of the sled. On my sled they are towards the front of the sled and the angled edge is towards the rear. This is the only way the brackets fit with the tunnel mod.
So... my question is, is this going to mess up the geometry of the Geo mod? With the two stock mounting holes being on the front already, it doesn't leave room for a 3rd hole to be drilled. The top hole on mine now is apprx 20mm down from the bend and about 11mm in from the front edge. Will the Geo mod still work & help my sled?
Thanks in advance for your guys help. I'm clueless on how to post pictures but I'm going to take one and see if I can figure out how to post it.
Okay, maybe I'm making this way more confusing that it has to be. How about this...
Can somebody who has done the Geo mod using the shaft collars on a 09 or newer suspension give me the center to center dimension for the upper suspension mounting bolt and the bolt that holds the stop on the rails. Naturally please make sure the suspension is all the way out - no sag.
I can adjust accordingly if I know that dimension. Thanks in advance.
did you try asking the guys on that site? I'm willing to bet you will get an answer pretty damn quick there ;)
