General ? on 03 700 RMK rocky mtn. king
I just purchased a 03 700 RMK it has 1300 miles on it. Appox. what should the compression be on this sled? What kind of gas should I burn in it? last question what jetting should I use for 4000' to 6000'?
I woul say around 130 to 150 on compression and fuel prem just make sure you run the key on the prem switch and for jetting I would say around 380's depending in your temp where you are riding
Thanks guys, I took a compression check and got 125 and 130. Someone pointed out the key switch and which gas you can pick. I put 91 octane in. It was already jetted for 6 to 9000' elev. I was able to take it up this weekend in the Bighorn Mtn's of Wyo. and it ran really well. I did get a jetting chart off this site as well. Thanks again for the feedback.
Target compression for the 03 700 is 145. If either cylinder is 125 or less, or if there's a 10+ PSI differential then it needs a top end.
Raise the bars, and put some boards on it. As for jetting...definitely put an ATACC on it.
I've got 4,000 trouble free miles on mine.
I quess I am just new to this game but not sure what " Raise the bars, and put some boards on it" means
The steering on the machine has already been raised? understand a little about jetting but not sure what ATACC is? Thanks
HOLTZMAN ATAAC
www.holtzmaneng.com
It's an automatic fuel compensator for carbed motors, costs approx $245.00 takes less than 1 hour to install.
It automatically adjusts for temperature and altitude changes.
Once you get your baseline jetting established you'll never have to re-jet again.
I had these on 2 of my own personal sleds, a 2002 EDDGE-X 800 and a 2001 EDGE-X 600, and installed them n 3 of my bud's EDGE's
Throttle response improves and mileage improves as well as performance.
Check out my "TECH TIPS FOR 700 & 800 EDGE's, FREE MODS & BEST BANG FOR THE BUCK" thread a lot of tips in there and the ATAAC is my #1 suggestion
