B
BordnBill
Just installed my Gen III's on my 08 Nytro MTX. First question is, is it normal that the Simmons saddle bolt in flush with the nyloc nut? From the looks of it, it looks like the bolt is just touching the nylon portion. I guess I'm use to the OEM bolt that sticks out about 1/2" past the nut.
Other question is, I noticed my OEM rubber saddles are pretty rough, so I need to get new one's. Microfiche is calling out two different numbers for these. 8-GL-23743-00-00 for the 08 and for the 09+ it is, 8-GP-23743-00-00. Other than the GL, GP difference in the number and price, they look the same. Should I go for the newer rubber or just stick with the 08 number? I did have to modify my OEM rubbers so they would sit flush on the Simmons Ski Saddles. The bolts were keeping the rubber from sitting flush.
Last question is, I notice that with the OEM saddles on the Simmons skis, there is not much up and down pivot when the skis are off the ground. This makes me nervous as when I come down hills onto the trail, I need to have some ski pivot. Is this normal?
Thanks everyone for the help.
