Gearing
O.B.
Has any one changed there drivers to gear down there 1100. Since there is not many choices if you want to keep reverse.
7 tooth Avids
I installed a 3" track last year, and used Avid 7 tooth drivers. Works well, and the added traction is a plus. Also installed a C3 syncrodrive late in the season, tried both the stock 2.33 ratio and the 2.42 ratio. With the 7 tooth drivers, I decided to use the stock 2.33 ratio, as the 2.42 in conjunction was a bit low for my tastes.
I totally agree. 7t drivers with the stock gearing put me right where I like to be. More clearance and lower gearing.
