gearing question
hey guys i just bought a belt drive (easier to turn or so they say) and it is a 32/62 combo which is about 1.94 it also came with a titanium drive shaft with 10t drivers, a stock king cat is 19/43 which is 2.26 with 8t drivers, the gear ratios and adding the ratios of the drivers confuses me, any advice will be awesome... options are a leave it alone
a lleave it how it is
b put the 8t drivers on
c leave the 10t and get a top gear made
d put the 8t on and get a top gear made,
any help at all specially if you know how to add in the driver tooth factor in the drive
More info needed!
I would suggest getting in the 2.3-2.4:1 range. But without knowing what sled you are putting it on, or where and what kind of riding you are doing? God only knows a good setup. I looked into a CMX setup but I couldnt get it geared the way I wanted to, so I lost interest. Good Luck! Post pics and tell us your results after you get it dialed. -00's
Oh, multiply the number of teeth by the pitch to get the rollout or circumferance.
8 tooth X 3.0 pitch = 24 inches of rollout
10 tooth X 2.52 pitch = 25.2 inches ect.
I think 00s left out the math you need. I think somewhere on here there is a formula for this but I look at it based on roll out for one revolution of the jackshaft (upper gear). So, I assume from your post you are on a King Cat with a 3.0 pitch track and if you assume the 2.3 (20/46 tooth gearing) that 00s said to aim for, you use the inverse ratio times the full rollout (one rev of the drivers). So the formula for a chain driven King would be:
(# upper teeth / # lower teeth) * (# driver teeth * pitch). For our example:
(20/46)*(8*3.0)= .43478*24 = 10.43478 inches you travel in one revolution of the jackshaft.
With your set up as you bought it:
(32/62)*(10*3.0) = 15.4839 or half again as far, so that is geared quite high. Your goal would be to solve the equation for an X (number of driver teeth or number of upper or lower gear teeth) that gets you close or maybe slightly under 10.43478 inches. If you stick with an 8 tooth driver and want to go with a bigger lower belt drive gear:
(32/x)*(8*3.0) = 10.43478
32/x * 24 = 10.43478
768/x = 10.43478
x = 768/10.43478
x = 73.6 teeth
So you would need a 32 tooth upper gear and a 74 tooth lower gear with 8 tooth drivers to be in the "2.3" ratio range.
Hope this makes some smese and isn't too much math. There may be an easier way.
Thanks, now it's time to try and find a sproket..... I think I will try to get a 26 or 27 top one because I think it will be cheaper if I do it that way, anyone know of anywhere that has something likethis let me know please!!!!
Hey how about this the 32/62 gearing and then run a 7t 3.0 driver so that would be
32/62=.516*(7x3)=10.383"per Jack shaft rotation....
What are the cons of running a smaller driver? Thanks!!!!!
So I read the negitive on smaller drivers is you have to run the track tighter, also it takes more power to turn, so basically a 8t has a 7.64" dia and a 7t would have a 6.68" dia so my question is would you really notice that.? If anyone who has ran differnt drivers could chime in that would be awesome
Gear ratio calculater
SLP has a great formula for calculating all of this, on their website. I printed copies and do a solution every time I make a clutch or gear change. I think you are on the right track, but I would stay away from the small drivers. It was almost impossible to get what I wanted. Keep us posted!
so i called up crazy mountain extream and he said i was crazy going anything lower then 2.14 he also said a 900 with porting, bored carbs, twins, head, and timing key should easily turn a 162 with that gearing. he said it all has to do with clutching so you can actually get more trackspeed... now im confused as hell.... good news i got ahold of white liteing bad news the smallest top gear is a 30 and 62 is the largest bottom gear, so
30/62=87.9mph @8000rpm
19/43=80.3mph @8000rpm
im looking for a 68 bottom but its really hard its basically a charger pulley in 8mm gt pitch which is easy to find but its a center flange which is almost imposible
if i was to clutch for this setup i would need a really sttep helix like a 60* and a heavy spring correct? im sorry i really know jack about clutching
I could agree with CMX on some applications, Took my 02 TC MC 162" gearing from 2.28 (previous owner gearing) to 2.10 - Much better pull,track speed,acceleration,topspeed, best of all more miles to the tank and clutches never get more than warm( O blown belts). With the torque of the cat 900 I would think gearing in that range would work.
finally found a 72t center!!!! so i will have the options of
32/62=1.93=93.84mph
30/62=2.06=87.97mph
32/72=2.25=80.80mph
30/72=2.40=75.75mph
stock 19/43=2.26=80.33mph
20/46=2.3=79.05
cool thing is i can change cears and run differnt ones in about 10min!!!!!
keep you guys posted!!!!
