Have a 2012 163 Pro since new
Played around for the last couple years with different clutch set ups on 100% stock machine. Carls setup was about the best for quick backshift and holding consistent RPM. 36-38 mph is about the best I could get for track speeds.
Shot connecting rod thru crankcase last spring....New shortblock under warranty. Decided to throw a "fix" into the brand new shortblock.
Went with RKT kit with 13.1 head to run straight premium fuel. Kelsey convinced me to try the Rooster weights as well. Also changed up gearing from stock 20-42 to 19-46 thinking I might gain a bit more trackspeed.....
Sled is running great, RKT kit is the real deal. Got the rooster weights loaded up in the heel with a bit in the mid and nothing in the tip.
RPM's are consistent at 8200, Kelsey recommends this setup to run 8300-8400 I'm just a little skeptical spinning this motor any faster....
Track speed hasn't changed from stock setup although she's a torquey SOB now!
What am I missing? Gearing have anything to do with Track speeds?
Should I lighten up weights for more RPM?
